path: root/doc/started/require.t (follow)
* Purged as many egcs references as possible.Joel Sherrill2000-06-101-2/+3
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-041-7/+27
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Fixing many lines that are too long to format cleanly.Joel Sherrill1999-10-251-8/+8
* Increased required disk space along with information about the requiredJoel Sherrill1998-10-201-3/+23
| | | | | | disk space. Added information about GNU makeinfo minimum version.
* Increased size of archive.Joel Sherrill1998-04-171-1/+1
* "arc" changed to "archive"Joel Sherrill1998-04-141-1/+1
| | | | Pictures now in ASCII.
* In texinfo nicely with all version dependent informationJoel Sherrill1998-04-101-0/+11
| | | | now in variables and some updates already in place.
* base versionJoel Sherrill1998-04-091-0/+25
