* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -8/+150 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Purged as many egcs references as possible. | Joel Sherrill | 2000-06-10 | 1 | -2/+3 |
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -7/+27 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 1 | -8/+8 |
* | Increased required disk space along with information about the required | Joel Sherrill | 1998-10-20 | 1 | -3/+23 |
| | | | | | | disk space. Added information about GNU makeinfo minimum version. | ||||
* | Increased size of archive. | Joel Sherrill | 1998-04-17 | 1 | -1/+1 |
* | "arc" changed to "archive" | Joel Sherrill | 1998-04-14 | 1 | -1/+1 |
| | | | | Pictures now in ASCII. | ||||
* | In texinfo nicely with all version dependent information | Joel Sherrill | 1998-04-10 | 1 | -0/+11 |
| | | | | now in variables and some updates already in place. | ||||
* | base version | Joel Sherrill | 1998-04-09 | 1 | -0/+25 |
