2002-11-13 | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -3/+2 | |
* Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -8/+150 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
2000-06-10 | Purged as many egcs references as possible. | Joel Sherrill | 1 | -2/+3 | |
2000-05-04 | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 1 | -7/+27 | |
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-25 | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1 | -8/+8 | |
1998-10-20 | Increased required disk space along with information about the required | Joel Sherrill | 1 | -3/+23 | |
disk space. Added information about GNU makeinfo minimum version. | |||||
1998-04-17 | Increased size of archive. | Joel Sherrill | 1 | -1/+1 | |
1998-04-14 | "arc" changed to "archive" | Joel Sherrill | 1 | -1/+1 | |
Pictures now in ASCII. | |||||
1998-04-10 | In texinfo nicely with all version dependent information | Joel Sherrill | 1 | -0/+11 | |
now in variables and some updates already in place. | |||||
1998-04-09 | base version | Joel Sherrill | 1 | -0/+25 | |
