* Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t,
sample.t, started.texi: General improvements and merge enough Ada
information to justify dropping the Ada specific manual. There is
likely still Ada specific information to merge though.
* Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi:
Removed all references to bit scripts.
* gdb.t: Removed.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
disk space.
Added information about GNU makeinfo minimum version.
Pictures now in ASCII.
now in variables and some updates already in place.
