path: root/doc/started/nt.t (follow)
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-261-316/+84
| | | | | * nt.t: Significant update of Windows information. Hopefully this is now more useful.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-191-1/+1
| | | | | | * .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t, nt.t, started.texi: Merge from branch. * tversions.texi.in: New file.
* 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-271-11/+11
| | | | | | * buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax).
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-131-3/+3
| | | | | | * Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-58/+81
* Purged as many egcs references as possible.Joel Sherrill2000-06-101-2/+2
* Updated NT editor information to update status on PFE and addJoel Sherrill2000-05-091-6/+24
| | | | pointers to emacs and vim.
* Modifed to avoid using @uref directive since that does not seemJoel Sherrill2000-05-041-4/+8
| | | | to work with pdf generation.
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-041-5/+5
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Modified to correct references to gmake per comment from Stephan WilmsJoel Sherrill2000-05-021-1/+1
| | | | <Stephan.Wilms@CWA.de>.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-011-24/+4
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* fixes from David FiddesJoel Sherrill1998-10-271-8/+6
* Update from David Fiddes.Joel Sherrill1998-10-271-108/+83
* Now builds for all formats and includes urlsJoel Sherrill1998-04-141-5/+29
* Comments from Geoffroy MontelJoel Sherrill1998-04-141-9/+26
* Now builds for all formats.Joel Sherrill1998-04-131-8/+8
| | | | Updated to include Steve's figures for the first time.
* Added Resources on the Internet sectionJoel Sherrill1998-04-131-0/+4
* New file based on Word document from Geoffroy Montel <g_montel@yahoo.com>Joel Sherrill1998-04-131-0/+347
who was assisted by D.J.Fiddes@hw.ac.uk.
