* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 1 | -278/+0 |
| | | | | | | * Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed. | ||||
* | 2001-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -1/+10 |
| | | | | | * buildc.t, gdb.t: Per PR54, updated to reflect multiple compression schemes including bzip2. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -111/+159 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Modified to correct references to gmake per comment from Stephan Wilms | Joel Sherrill | 2000-05-02 | 1 | -3/+6 |
| | | | | <Stephan.Wilms@CWA.de>. | ||||
* | Merged changes from 4.5 branch and removed that branch. | Joel Sherrill | 2000-04-25 | 1 | -9/+0 |
* | Adding information on prebuilt toolset binaries. | Joel Sherrill | 2000-02-22 | 1 | -1/+6 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added information about the bit_gdb script. | Joel Sherrill | 1998-10-20 | 1 | -3/+35 |
* | "arc" changed to "archive" | Joel Sherrill | 1998-04-14 | 1 | -2/+2 |
| | | | | Pictures now in ASCII. | ||||
* | Mostly correcting case of section headings although a few minor things | Joel Sherrill | 1998-04-11 | 1 | -14/+10 |
| | | | | | were corrected as the Getting Started with GNAT/RTEMS manual was created. | ||||
* | Printed copy given to Steve and Mark | Joel Sherrill | 1998-04-10 | 1 | -4/+4 |
* | In texinfo nicely with all version dependent information | Joel Sherrill | 1998-04-10 | 1 | -76/+94 |
| | | | | now in variables and some updates already in place. | ||||
* | Now builds clean for info, html, and ps. | Joel Sherrill | 1998-04-09 | 1 | -14/+14 |
* | base version | Joel Sherrill | 1998-04-09 | 1 | -0/+176 |
