* | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-25 | 1 | -4/+4 |
| | | | | * setup.def, started/buildc.t: Update. | ||||
* | 2008-06-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-06-06 | 1 | -0/+13 |
| | | | | | | * started/buildc.t: Add paragraph on see CVS for latest patches. * user/conf.t: Add CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE and example of how to compute message CONFIGURE_MESSAGE_BUFFER_MEMORY using it. | ||||
* | Replace nosrc.rpm with src.rpm | Ralf Corsepius | 2007-01-15 | 1 | -6/+6 |
* | More tweaks. | Ralf Corsepius | 2007-01-15 | 1 | -12/+12 |
* | More tweaks. | Ralf Corsepius | 2007-01-15 | 1 | -22/+22 |
* | 2007-01-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-15 | 1 | -16/+13 |
| | | | | | * started/binaries.t, started/buildc.t, started/tversions.texi.in: Various update to reflect current toolchains. | ||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -1/+1 |
| | | | | | | | | | * FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi, FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi, FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti, FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t, started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and regenerate. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 1 | -3/+0 |
| | | | | | | * configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry, porting/cpumodels.t, started/buildc.t, started_ada/buildada.t, user/preface.texi: i960 obsoleted. | ||||
* | 2004-09-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-27 | 1 | -2/+3 |
| | | | | | | | | PR 681/doc PR 682/doc * buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable binutils link again. * user/overview.t: Chapter numbering in preface was wrong. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 1 | -1/+1 |
| | | | | | * started/buildc.t: Use tar xjf for bzip'ed files. * started/buildrt.t: Use tar xjf to unzip rtems. | ||||
* | 2004-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-02-04 | 1 | -7/+5 |
| | | | | | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html, gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/require.t, started/sample.t, started/tversions.texi.in: Incorporating changes from pre-4.6.0 review. | ||||
* | 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-01 | 1 | -21/+21 |
| | | | | * binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms. | ||||
* | 2003-10-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-10-02 | 1 | -9/+56 |
| | | | | | | | * Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t, sample.t, started.texi: General improvements and merge enough Ada information to justify dropping the Ada specific manual. There is likely still Ada specific information to merge though. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 1 | -89/+82 |
| | | | | | | * .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t, nt.t, started.texi: Merge from branch. * tversions.texi.in: New file. | ||||
* | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-27 | 1 | -112/+112 |
| | | | | | | * buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax). | ||||
* | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-22 | 1 | -4/+28 |
| | | | | | | PR 469/doc * buildc.t: Clarifying text on patch file to account for various ways they could be compressed or not. | ||||
* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-08-07 | 1 | -0/+4 |
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 1 | -292/+6 |
| | | | | | | * Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed. | ||||
* | 2001-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -5/+11 |
| | | | | | * buildc.t, gdb.t: Per PR54, updated to reflect multiple compression schemes including bzip2. | ||||
* | 2002-03-20 Chris Johns <ccj@acm.org> | Joel Sherrill | 2002-03-20 | 1 | -0/+15 |
| | | | | | | * PR137 * buildc.t: Now provides more explicit requirements on $PATH after building binutils. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -218/+719 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Purged as many egcs references as possible. | Joel Sherrill | 2000-06-10 | 1 | -2/+2 |
* | Corrected paths. | Joel Sherrill | 2000-05-17 | 1 | -3/+3 |
* | Modifed to avoid using @uref directive since that does not seem | Joel Sherrill | 2000-05-04 | 1 | -6/+12 |
| | | | | to work with pdf generation. | ||||
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -13/+87 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Adding information on prebuilt toolset binaries. | Joel Sherrill | 2000-02-22 | 1 | -0/+4 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -6/+6 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Added common problems section after post by Philippe Le Foll | Joel Sherrill | 1999-01-21 | 1 | -0/+81 |
| | | | | <Philippe.LeFoll@fridu.com> on rtems-list. :) | ||||
* | Update from David Fiddes. | Joel Sherrill | 1998-10-27 | 1 | -0/+16 |
* | Added information about the new build scripts. The biggest thing was | Joel Sherrill | 1998-10-20 | 1 | -59/+73 |
| | | | | | | describing the user.cfg file. Added a section on Solaris 2.x. | ||||
* | Added a warning about positioning the INSTALL_POINT under the build | Joel Sherrill | 1998-08-13 | 1 | -0/+4 |
| | | | | tree. | ||||
* | Used http reference for EGCS index. | Joel Sherrill | 1998-04-17 | 1 | -4/+4 |
* | "arc" changed to "archive" | Joel Sherrill | 1998-04-14 | 1 | -70/+61 |
| | | | | Pictures now in ASCII. | ||||
* | Now builds for all formats and includes urls | Joel Sherrill | 1998-04-14 | 1 | -12/+15 |
* | Added urls as links | Joel Sherrill | 1998-04-14 | 1 | -8/+20 |
* | Added rudimentary section on reading the documentation for each tool | Joel Sherrill | 1998-04-14 | 1 | -0/+10 |
* | Suggestions from Eric Norum | Joel Sherrill | 1998-04-14 | 1 | -76/+68 |
* | added ASCII versions of directory tree figures | Joel Sherrill | 1998-04-13 | 1 | -4/+22 |
* | Now builds for all formats. | Joel Sherrill | 1998-04-13 | 1 | -12/+77 |
| | | | | Updated to include Steve's figures for the first time. | ||||
* | Added Resources on the Internet section | Joel Sherrill | 1998-04-13 | 1 | -8/+7 |
* | Added Cygwin32 Chapter | Joel Sherrill | 1998-04-13 | 1 | -0/+2 |
* | Mostly correcting case of section headings although a few minor things | Joel Sherrill | 1998-04-11 | 1 | -2/+10 |
| | | | | | were corrected as the Getting Started with GNAT/RTEMS manual was created. | ||||
* | Printed copy given to Steve and Mark | Joel Sherrill | 1998-04-10 | 1 | -2/+2 |
* | In texinfo nicely with all version dependent information | Joel Sherrill | 1998-04-10 | 1 | -66/+191 |
| | | | | now in variables and some updates already in place. | ||||
* | Now builds clean for info, html, and ps. | Joel Sherrill | 1998-04-09 | 1 | -31/+191 |
* | base version | Joel Sherrill | 1998-04-09 | 1 | -0/+66 |
