2003-08-27 | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -112/+112 | |
* buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax). | |||||
2003-08-22 | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -4/+28 | |
PR 469/doc * buildc.t: Clarifying text on patch file to account for various ways they could be compressed or not. | |||||
2003-08-07 | Merger from rtems-4-6-branch | Ralf Corsepius | 1 | -0/+4 | |
2002-11-13 | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -292/+6 | |
* Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed. | |||||
2002-06-28 | 2001-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -5/+11 | |
* buildc.t, gdb.t: Per PR54, updated to reflect multiple compression schemes including bzip2. | |||||
2002-03-20 | 2002-03-20 Chris Johns <ccj@acm.org> | Joel Sherrill | 1 | -0/+15 | |
* PR137 * buildc.t: Now provides more explicit requirements on $PATH after building binutils. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -218/+719 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
2000-06-10 | Purged as many egcs references as possible. | Joel Sherrill | 1 | -2/+2 | |
2000-05-17 | Corrected paths. | Joel Sherrill | 1 | -3/+3 | |
2000-05-04 | Modifed to avoid using @uref directive since that does not seem | Joel Sherrill | 1 | -6/+12 | |
to work with pdf generation. | |||||
2000-05-04 | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 1 | -13/+87 | |
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
2000-02-22 | Adding information on prebuilt toolset binaries. | Joel Sherrill | 1 | -0/+4 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-25 | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1 | -1/+1 | |
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -6/+6 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1999-01-21 | Added common problems section after post by Philippe Le Foll | Joel Sherrill | 1 | -0/+81 | |
<Philippe.LeFoll@fridu.com> on rtems-list. :) | |||||
1998-10-27 | Update from David Fiddes. | Joel Sherrill | 1 | -0/+16 | |
1998-10-20 | Added information about the new build scripts. The biggest thing was | Joel Sherrill | 1 | -59/+73 | |
describing the user.cfg file. Added a section on Solaris 2.x. | |||||
1998-08-13 | Added a warning about positioning the INSTALL_POINT under the build | Joel Sherrill | 1 | -0/+4 | |
tree. | |||||
1998-04-17 | Used http reference for EGCS index. | Joel Sherrill | 1 | -4/+4 | |
1998-04-14 | "arc" changed to "archive" | Joel Sherrill | 1 | -70/+61 | |
Pictures now in ASCII. | |||||
1998-04-14 | Now builds for all formats and includes urls | Joel Sherrill | 1 | -12/+15 | |
1998-04-14 | Added urls as links | Joel Sherrill | 1 | -8/+20 | |
1998-04-14 | Added rudimentary section on reading the documentation for each tool | Joel Sherrill | 1 | -0/+10 | |
1998-04-14 | Suggestions from Eric Norum | Joel Sherrill | 1 | -76/+68 | |
1998-04-13 | added ASCII versions of directory tree figures | Joel Sherrill | 1 | -4/+22 | |
1998-04-13 | Now builds for all formats. | Joel Sherrill | 1 | -12/+77 | |
Updated to include Steve's figures for the first time. | |||||
1998-04-13 | Added Resources on the Internet section | Joel Sherrill | 1 | -8/+7 | |
1998-04-13 | Added Cygwin32 Chapter | Joel Sherrill | 1 | -0/+2 | |
1998-04-11 | Mostly correcting case of section headings although a few minor things | Joel Sherrill | 1 | -2/+10 | |
were corrected as the Getting Started with GNAT/RTEMS manual was created. | |||||
1998-04-10 | Printed copy given to Steve and Mark | Joel Sherrill | 1 | -2/+2 | |
1998-04-10 | In texinfo nicely with all version dependent information | Joel Sherrill | 1 | -66/+191 | |
now in variables and some updates already in place. | |||||
1998-04-09 | Now builds clean for info, html, and ps. | Joel Sherrill | 1 | -31/+191 | |
1998-04-09 | base version | Joel Sherrill | 1 | -0/+66 | |
