closes #2812.
* fix and remove some macros in rtems.texi.in.
* refer to devel mailing list.
* remove reference to Debian packaging in requirements section.
* remove section on prebuilt tools.
* replace toolset build instructions with link to RSB docs.
* Add a note in building RTEMS section about using RSB.
* Fix URLs
Closes #2291.
for details.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
* Makefile.am: Add tversions.texi.in to EXTRA_DIST.
* Makefile.am: Cosmetics.
* Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t,
sample.t, started.texi: General improvements and merge enough Ada
information to justify dropping the Ada specific manual. There is
likely still Ada specific information to merge though.
* configure.ac: Require autoconf-2.57.
Require automake-1.7.2.
Remove started/pictures/Makefile.
* started/Makefile.am: Merge-in pictures/Makefile.am
* started/pictures/Makefile.am: Remove.
* Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi:
Removed all references to bit scripts.
* gdb.t: Removed.
* pictures/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Include main.am, require automake-1.5.
* pictures/Makefile.am: Require automake-1.5, fix +=.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
tries to give a pointer about how to approach writing an application.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
