* | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-27 | 1 | -0/+6 |
| | | | | | | * buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax). | ||||
* | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-22 | 1 | -0/+6 |
| | | | | | | PR 469/doc * buildc.t: Clarifying text on patch file to account for various ways they could be compressed or not. | ||||
* | 2003-08-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-22 | 1 | -0/+4 |
| | | | | * tversions.texi: Correcting version information. | ||||
* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-08-07 | 1 | -0/+10 |
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 1 | -0/+4 |
| | | | | * tversions.texi: Updated tool version numbers. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 1 | -0/+4 |
| | | | | * started.texi: Set @setfilename started.info. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 1 | -0/+4 |
| | | | | * Makefile.am: Put GENERATED_FILES into $builddir. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 1 | -0/+8 |
| | | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | ||||
* | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-21 | 1 | -0/+4 |
| | | | | * stamp-vti, version.texi: Regenerated. | ||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 1 | -0/+6 |
| | | | | | | * Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed. | ||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 1 | -0/+4 |
* | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-24 | 1 | -0/+4 |
* | 2001-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -0/+4 |
| | | | | * tverstions.texi: Updated to reflect newer versions. | ||||
* | 2001-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -0/+5 |
| | | | | | * buildc.t, gdb.t: Per PR54, updated to reflect multiple compression schemes including bzip2. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+5 |
| | | | | | * pictures/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-03-20 Chris Johns <ccj@acm.org> | Joel Sherrill | 2002-03-20 | 1 | -0/+6 |
| | | | | | | * PR137 * buildc.t: Now provides more explicit requirements on $PATH after building binutils. | ||||
* | 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-18 | 1 | -0/+6 |
| | | | | | * Makefile.am: Include main.am, require automake-1.5. * pictures/Makefile.am: Require automake-1.5, fix +=. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -0/+4 |
| | | | | * .cvsignore: Added rtems_header.html and rtems_footer.html. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-25 | 1 | -0/+3 |
