* shell/general.t: Add sleep and echo commands.
* shell/.cvsignore, shell/Makefile.am, shell/memory.t,
shell/preface.texi, shell/shell.texi: Added much information the
Preface. Created initial version of Configuration and Intialization
chapter. Links are now complete from start to end of manual.
* shell/confinit.t: New file.
* shell/file.t, shell/network.t: Document more commands and provide
more examples.
* shell/file.t, shell/general.t, shell/memory.t, shell/network.t,
shell/rtems.t, shell/shell.texi: Many commands now have real
descriptions with examples.
* shell/file.t, shell/general.t: More commands documented.
* shell/.cvsignore, shell/file.t: Add most of file commands.
shell/rtems.t: More descriptions and examples added.
shell/rtems.t: Add mount and cp command information from Chris Johns.
Reformat some things.
shell/rtems.t: A bit of clean up on the script.
shell/rtems.t: Change configure messages per Chris Johns suggestion.
* Makefile.am, configure.ac, index.html.in: Add initial version of
RTEMS Shell Manual. This is largely a starting point but has most of
the required structure.
* shell/.cvsignore, shell/Makefile.am, shell/file.t, shell/general.t,
shell/memory.t, shell/network.t, shell/preface.texi, shell/rtems.t,
shell/shell.texi: New files.
