* Makefile.am, configure.ac, develenv/direct.t: Remove RDBG.
* rgdb_specs/.cvsignore, rgdb_specs/Makefile.am, rgdb_specs/comm.t,
rgdb_specs/conclusion.t, rgdb_specs/daemon.t,
rgdb_specs/gdbinternals.t, rgdb_specs/interfacing.t,
rgdb_specs/intro.t, rgdb_specs/layers.eps, rgdb_specs/layers.jpg,
rgdb_specs/layers.txt, rgdb_specs/objectives.t,
rgdb_specs/process.eps, rgdb_specs/process.jpg,
rgdb_specs/process.txt, rgdb_specs/revision.t,
rgdb_specs/rgdb_specs.texi, rgdb_specs/seqbreak.eps,
rgdb_specs/seqbreak.jpg, rgdb_specs/seqbreak.txt,
rgdb_specs/seqdetach.eps, rgdb_specs/seqdetach.jpg,
rgdb_specs/seqdetach.txt, rgdb_specs/seqinit.eps,
rgdb_specs/seqinit.jpg, rgdb_specs/seqinit.txt, rtems_gdb/.cvsignore,
rtems_gdb/Makefile.am, rtems_gdb/commands.t, rtems_gdb/example.t,
rtems_gdb/intro.t, rtems_gdb/rtems_gdb.texi, rtems_gdb/started.t,
rtems_gdb/swarch.t, rtems_gdb/trouble.t: Removed.
* Makefile.am: Cosmetics.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
