1999-04-02 | Can now produce html, info, and PostScript without errors. Links | Joel Sherrill | 7 | -61/+67 | |
between chapters are correct. | |||||
1999-04-02 | Accidentally added the .tex file not the .texi root document. | Joel Sherrill | 3 | -1234/+115 | |
Also the Makefile had "@include" lines in it. | |||||
1999-04-02 | New files. This manual was ritten by Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 16 | -0/+12427 | |
and Emmanuel Raguet <raguet@crf.canon.fr>. It was submitted in LaTeX and converted to Texinfo by Joel. At this point, the figures are largely ignored except to put in an example block to show they are missing. The Makefile should be just enough to produce output with no links between chapters. |
