* Makefile.am: Cosmetics.
* rgdb_specs.texi: Merge from branch.
* daemon.t: Reflect c/src/exec having moved to cpukit.
* rgdb_specs.texi: Set @setfilename rgdb_specs.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
not like the generated pdf but who knows what that really means.
figures included.
there are no captions.
between chapters are correct.
Also the Makefile had "@include" lines in it.
and Emmanuel Raguet <raguet@crf.canon.fr>. It was submitted in LaTeX
and converted to Texinfo by Joel. At this point, the figures are
largely ignored except to put in an example block to show they are
missing.
The Makefile should be just enough to produce output with no links between
chapters.
