* | Renamed seq_break.eps to seqbreak.eps. | Joel Sherrill | 1999-10-06 | 1 | -0/+0 |
* | Renamed seg_init to seq_init. | Joel Sherrill | 1999-10-06 | 4 | -7/+19 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 2 | -3/+8 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Now at least a version of the figures shows up in the html although | Joel Sherrill | 1999-04-02 | 9 | -7/+150 |
| | | | | there are no captions. | ||||
* | Can now produce html, info, and PostScript without errors. Links | Joel Sherrill | 1999-04-02 | 7 | -61/+67 |
| | | | | between chapters are correct. | ||||
* | Accidentally added the .tex file not the .texi root document. | Joel Sherrill | 1999-04-02 | 3 | -1234/+115 |
| | | | | Also the Makefile had "@include" lines in it. | ||||
* | New files. This manual was ritten by Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 1999-04-02 | 16 | -0/+12427 |
and Emmanuel Raguet <raguet@crf.canon.fr>. It was submitted in LaTeX and converted to Texinfo by Joel. At this point, the figures are largely ignored except to put in an example block to show they are missing. The Makefile should be just enough to produce output with no links between chapters. |
