* | Use @image for ASCII figures (Reflect changes above). | Ralf Corsepius | 2004-08-02 | 1 | -64/+9 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 1 | -11/+14 |
* | Enabled images. Works pretty well for PostScript. Ghostview does | Joel Sherrill | 1999-10-06 | 1 | -23/+25 |
| | | | | not like the generated pdf but who knows what that really means. | ||||
* | Renamed seg_init to seq_init. | Joel Sherrill | 1999-10-06 | 1 | -5/+5 |
* | Now at least a version of the figures shows up in the html although | Joel Sherrill | 1999-04-02 | 1 | -6/+96 |
| | | | | there are no captions. | ||||
* | Can now produce html, info, and PostScript without errors. Links | Joel Sherrill | 1999-04-02 | 1 | -5/+5 |
| | | | | between chapters are correct. | ||||
* | New files. This manual was ritten by Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 1999-04-02 | 1 | -0/+214 |
and Emmanuel Raguet <raguet@crf.canon.fr>. It was submitted in LaTeX and converted to Texinfo by Joel. At this point, the figures are largely ignored except to put in an example block to show they are missing. The Makefile should be just enough to produce output with no links between chapters. |
