Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
