path: root/doc/relnotes (follow)
* Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2000-05-011-9/+9
| | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
* New files. First attempt.Joel Sherrill2000-04-271-0/+17
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-262-53/+21
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Changed copyright date to 1999.Joel Sherrill1999-11-166-6/+6
* Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1999-10-111-3/+4
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-071-1/+1
| | | | pdf version of figures.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-012-3/+8
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Removed concept of distribution level.Joel Sherrill1999-07-031-1/+0
* Version changed.Joel Sherrill1998-10-271-8/+0
* Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1998-03-301-15/+7
* Corrected distribution levels for htmlJoel Sherrill1998-03-301-1/+1
* Added distribution level to each manualJoel Sherrill1998-03-301-2/+3
* Added variables for dates and revision infoJoel Sherrill1998-03-261-4/+4
* Updated copyrightsJoel Sherrill1998-02-066-6/+6
* minor updates .. mostly versionJoel Sherrill1998-01-231-4/+5
* corrected typos and changes LANGUAGE to RTEMS-LANGUAGE.Joel Sherrill1997-07-314-9/+9
* added CVS Id stringJoel Sherrill1997-06-046-0/+12
* changed edition and version informationJoel Sherrill1997-06-041-2/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-2/+2
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* fixed typosJoel Sherrill1997-05-301-5/+5
* version changedJoel Sherrill1997-05-281-2/+2
* 4.0.0 release docsJoel Sherrill1997-05-281-2/+2
* Initial revisionJoel Sherrill1997-05-276-0/+884
