* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 1 | -5/+0 |
| | | | | * intro.texi, status.texi: i960 obsoleted. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 1 | -5/+0 |
| | | | | * status.texi: Obsoleting HP PA-RISC port and removing all references. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 1 | -68/+3 |
| | | | | | * install.texi, intro.texi, relnotes.texi, status.texi: Merge from branch. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct problems | Joel Sherrill | 2000-06-12 | 1 | -3/+3 |
| | | | | on RELEASE versus VERSION. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | corrected typos and changes LANGUAGE to RTEMS-LANGUAGE. | Joel Sherrill | 1997-07-31 | 1 | -3/+3 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+258 |
