closes #2812.
In PDF, DVI, and PostScript files, the contents of the @top
node were being printed. These are intended only for info
and html output formats.
Texinfo 5.0 is a complete reimplementation and has stricter
interpretations of the texinfo language.
PR 1793/doc
* .cvsignore, install.texi, intro.texi, probrep.texi, relnotes.texi,
status.texi: Convert from texi2www to texi2html.
* relnotes.texi: Print table of contents in front of manual where it
should be when you print.
* install.texi, intro.texi, relnotes.texi, status.texi: Merge from
branch.
* relnotes.texi: Set @setfilename relnotes.info.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
figures included.
to be correct in either C or Ada.
Added the interrupt disable, enable, flash, and is in progress directives.
changed "97" to "1997"
