1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1 | -3/+4 | |
1999-10-07 | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1 | -1/+1 | |
pdf version of figures. | |||||
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -2/+7 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1999-07-03 | Removed concept of distribution level. | Joel Sherrill | 1 | -1/+0 | |
1998-03-30 | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1 | -15/+7 | |
1998-03-30 | Corrected distribution levels for html | Joel Sherrill | 1 | -1/+1 | |
1998-03-30 | Added distribution level to each manual | Joel Sherrill | 1 | -2/+3 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+53 | |
