* configure.ac: Add c4x.
* project.am: Add version.texi hack.
* main.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF.
Append -I $(top_builddir) to TEXI2WWW_ARGS.
* project.am: Add AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF.
Override automake's .dvi.ps:-rule.
* project.am, main.am: Use automake rules to build ps, pdf, info.
Various minor changes.
* project.am: Append $($(PROJECT)_TEXINFOS) to
html-dependencies.
* project.am: Use PATH_SEPARATOR to setup TEXINPUTS.
* .cvsignore: Reworked.
* Makefile.am: Remove texinfo/texinfo.tex
* bootstrap: Removed.
* configure.ac: Add pkgdocdir. Let htmldir be rooted at pkgdocdir.
* main.am: Remove TEXINFO_TEX.
* project.am: Let dvidir, psdir, pdfdir be rooted at pkgdocdir.
Remove commented out make-variables.
* .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing,
mkinstalldirs, texinfo.tex.
* Makefile.am: Add main.am to AUTOMAKE_FILES.
* configure.ac: Add AC_CONFIG_AUX_DIR([.]).
* project.am: Remove custom .texi and stamp-vti rules.
* main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* project.am: Reworked.
* main.am: New.
* configure.ac: New.
* configure.in: Removed.
* bootstrap: Sync with RTEMS's toplevel bootstrap.sh.
<corsepiu@faw.uni-ulm.de> to address build problems
effecting RedHat users but not SuSE users.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
