* posix_users/preface.texi, shell/preface.texi: Add stock
acknowledgement paragraphs that are required when excerpting and
reusing text from POSIX standards per the agreement at
* common/opengroup_manpage_acknowledgement.texi,
common/opengroup_preface_acknowledgement.texi: New files.
PR 1291/cpukit
* posix_users/semaphores.t: Update to reflect absolute time.
* posix_users/mutex.t: Add ETIMEDOUT.
PR 1262/filesystem
* posix_users/io.t: Add support for readv() and writev() including
documentation and test case.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* posix_users/thread.t: Correct spelling error.
* posix_users/.cvsignore, rgdb_specs/.cvsignore, rtems_gdb/.cvsignore,
started/.cvsignore, started_ada/.cvsignore: Add more generated files.
* ChangeLog: Merge-in posix_users/ChangeLog.
* ChangeLog: Merge-in posix1003.1/ChangeLog.
* ChangeLog: Merge-in itron3.0/ChangeLog.
* posix_users/ChangeLog, posix1003.1/ChangeLog, itron3.0/ChangeLog:
Remove.
PR 464/doc
* clock.t, signal.t: Add documentation for usleep() and ualarm(). Also
fixed a couple of calls which have the wrong .h files per the
OpenGroup site documentation.
* Makefile.am: Cosmetics.
* posix_users.texi: Merge from branch.
PR 466/doc
* io.t: Added sync().
* posix_users.texi: Set @setfilename posix_users.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* preface.texi, procenv.t, process.t, signal.t, stamp-vti,
version.texi: Updated as part of starting a sweep on the POSIX
User's Guide.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
The message queue manager chapter needs to be updated to reflect
completion of the implementation.
accurate description.
