* | Added a comment. | Joel Sherrill | 2000-02-23 | 1 | -0/+4 |
* | Added POSIX interpretation subsection and updated status. | Joel Sherrill | 2000-01-13 | 2 | -4/+16 |
| | | | | | The message queue manager chapter needs to be updated to reflect completion of the implementation. | ||||
* | Fixed typos. | Joel Sherrill | 2000-01-04 | 2 | -11/+12 |
* | Updated dates and miscellaneous. | Joel Sherrill | 2000-01-04 | 2 | -7/+16 |
* | Updated. | Joel Sherrill | 1999-11-29 | 3 | -276/+324 |
* | Removed bad descriptions of mount() and umount(). Added shell of an | Joel Sherrill | 1999-11-29 | 1 | -124/+25 |
| | | | | accurate description. | ||||
* | Added chapter of list of routines provided by libm. | Joel Sherrill | 1999-11-24 | 4 | -17/+102 |
* | New file. | Joel Sherrill | 1999-11-24 | 1 | -0/+154 |
* | Added routines included by C library. | Joel Sherrill | 1999-11-24 | 4 | -2/+336 |
* | Added sem_timedwait to bullet list at front of chapter. | Joel Sherrill | 1999-11-23 | 1 | -0/+1 |
* | Added descriptions for bullet list and routine section headings. | Joel Sherrill | 1999-11-23 | 1 | -8/+8 |
* | Added Timer Manager Chapter. | Joel Sherrill | 1999-11-23 | 2 | -1/+8 |
* | Fixed line too long. | Joel Sherrill | 1999-11-23 | 1 | -2/+2 |
* | New file. | Joel Sherrill | 1999-11-23 | 1 | -0/+196 |
* | Fixed spacing. | Joel Sherrill | 1999-11-16 | 12 | -175/+185 |
* | Corrected status. | Joel Sherrill | 1999-11-16 | 1 | -2/+2 |
* | Fixed spacing. | Joel Sherrill | 1999-11-16 | 2 | -48/+48 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 20 | -20/+20 |
* | Added status chapter. | Joel Sherrill | 1999-11-16 | 3 | -2/+73 |
* | Cleaned up spacing on function prototypes. | Joel Sherrill | 1999-10-28 | 1 | -56/+56 |
* | Added lstat(). | Joel Sherrill | 1999-10-28 | 1 | -3/+57 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 4 | -18/+10 |
* | Fixed random cut and paste problem. | Joel Sherrill | 1999-10-11 | 1 | -23/+23 |
* | Added files generated by index process to clean stanza. | Joel Sherrill | 1999-10-11 | 1 | -0/+1 |
* | Generated concept and function index entries. | Joel Sherrill | 1999-10-11 | 19 | -1171/+2626 |
* | Added descriptions. | Joel Sherrill | 1999-10-11 | 2 | -61/+88 |
* | Updated to incldue descriptions and reformatted to wrap lines better. | Joel Sherrill | 1999-10-11 | 1 | -93/+396 |
* | Added descriptions of routines to section headings. | Joel Sherrill | 1999-10-11 | 3 | -80/+80 |
* | Added descriptions. | Joel Sherrill | 1999-10-11 | 3 | -38/+66 |
* | Now build. | Joel Sherrill | 1999-10-11 | 3 | -175/+489 |
* | Added enough to let script find that this does not have descriptions. | Joel Sherrill | 1999-10-11 | 1 | -10/+10 |
* | Make sure directories are made before installing and install html, | Joel Sherrill | 1999-10-11 | 1 | -3/+4 |
| | | | | pdf, ps, and dvi into the html directory so they all can be browsed. | ||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 4 | -9/+14 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Filled in. | Joel Sherrill | 1999-07-01 | 1 | -10/+30 |
* | Directives -> services. | Joel Sherrill | 1999-06-15 | 1 | -4/+4 |
* | Some stuff added. | Joel Sherrill | 1999-06-15 | 1 | -38/+131 |
* | Significantly enhanced. At least the per routine pages for this chapter | Joel Sherrill | 1999-06-15 | 1 | -59/+349 |
| | | | | are now filled in. | ||||
* | Added information on pathname evaluation. | Joel Sherrill | 1999-06-11 | 1 | -1/+14 |
* | Fixed Makefile to avoid copying the file to a new name. | Joel Sherrill | 1999-04-23 | 1 | -1/+0 |
* | Changed date. | Joel Sherrill | 1999-04-23 | 2 | -3/+3 |
* | Changed version string. | Joel Sherrill | 1998-11-19 | 2 | -23/+151 |
| | | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | ||||
* | Added. | Joel Sherrill | 1998-11-19 | 1 | -0/+175 |
* | Readded preface | Joel Sherrill | 1998-11-19 | 1 | -0/+34 |
* | Major update/merge of POSIX manual. | Joel Sherrill | 1998-11-19 | 19 | -741/+6740 |
* | Posix users manual now makes multiple info files. | Joel Sherrill | 1998-08-24 | 1 | -2/+2 |
* | Updated to include standard number. | Joel Sherrill | 1998-08-13 | 1 | -4/+7 |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 1 | -15/+8 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 1 | -1/+1 |
