2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Fixed spacing. | Joel Sherrill | 1 | -4/+4 | |
1999-11-16 | Fixed spacing. | Joel Sherrill | 1 | -44/+44 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-25 | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1 | -4/+4 | |
1999-10-11 | Generated concept and function index entries. | Joel Sherrill | 1 | -141/+291 | |
1999-06-15 | Directives -> services. | Joel Sherrill | 1 | -4/+4 | |
1999-06-15 | Significantly enhanced. At least the per routine pages for this chapter | Joel Sherrill | 1 | -59/+349 | |
are now filled in. | |||||
1998-11-19 | Major update/merge of POSIX manual. | Joel Sherrill | 1 | -0/+0 | |
1998-09-29 | Added sentence to indicate sections were deliberately empty. | Joel Sherrill | 1 | -0/+2 | |
1998-08-01 | Removed all node and menu information since this information is now | Joel Sherrill | 1 | -137/+2 | |
automatically generated. Removed any attempts to link across chapter boundaries since the manual is incomplete. | |||||
1998-08-01 | Added automatic generation of files. | Joel Sherrill | 1 | -0/+0 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+1023 | |
