2011-01-10 | 2011-01-10 Danila Bespalov <danila DOT bespalov AT gmail DOT com> | Joel Sherrill | 1 | -67/+196 | |
* posix_users/posix_users.texi, posix_users/signal.t: Review and improve as part of Google Code-In 2010. | |||||
2004-01-09 | 2004-01-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -3/+65 | |
PR 464/doc * clock.t, signal.t: Add documentation for usleep() and ualarm(). Also fixed a couple of calls which have the wrong .h files per the OpenGroup site documentation. | |||||
2002-06-28 | 2001-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -7/+54 | |
* preface.texi, procenv.t, process.t, signal.t, stamp-vti, version.texi: Updated as part of starting a sweep on the POSIX User's Guide. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Fixed spacing. | Joel Sherrill | 1 | -34/+34 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Generated concept and function index entries. | Joel Sherrill | 1 | -115/+223 | |
1998-11-19 | Major update/merge of POSIX manual. | Joel Sherrill | 1 | -0/+0 | |
1998-11-19 | Applied updates from remote work while doing class. | Joel Sherrill | 1 | -0/+2 | |
1998-10-12 | Added message to "return -1 and set errno". | Joel Sherrill | 1 | -5/+11 | |
1998-09-29 | Fleshed out considerably. This is almost a passable manual now. | Joel Sherrill | 1 | -49/+186 | |
1998-08-01 | Removed all node and menu information since this information is now | Joel Sherrill | 1 | -109/+1 | |
automatically generated. Removed any attempts to link across chapter boundaries since the manual is incomplete. | |||||
1998-08-01 | Added automatic generation of files. | Joel Sherrill | 1 | -0/+0 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+689 | |
