* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2011-12-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-06 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | PR 1793/doc * .cvsignore, Makefile.am, README, configure.ac, index.html.in, main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi, ada_user/example.texi, bsp_howto/.cvsignore, bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore, cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi, develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi, filesystem/.cvsignore, filesystem/filesystem.texi, filesystem/preface.texi, networking/.cvsignore, networking/networking.texi, networking/preface.texi, porting/.cvsignore, porting/porting.texi, porting/preface.texi, posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi, posix_users/.cvsignore, posix_users/posix_users.texi, posix_users/preface.texi, shell/.cvsignore, shell/preface.texi, shell/shell.texi, started/.cvsignore, started/started.texi, user/.cvsignore, user/c_user.texi, user/dirstat.texi, user/example.texi, user/glossary.texi, user/preface.texi: Convert from texi2www to texi2html. * texi2html_init.in: New file. * rtems_footer.html.in, rtems_header.html.in: Removed. | ||||
* | 2009-02-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-27 | 1 | -0/+4 |
| | | | | | | | | * posix_users/preface.texi, shell/preface.texi: Add stock acknowledgement paragraphs that are required when excerpting and reusing text from POSIX standards per the agreement at * common/opengroup_manpage_acknowledgement.texi, common/opengroup_preface_acknowledgement.texi: New files. | ||||
* | 2001-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -3/+5 |
| | | | | | | * preface.texi, procenv.t, process.t, signal.t, stamp-vti, version.texi: Updated as part of starting a sweep on the POSIX User's Guide. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Readded preface | Joel Sherrill | 1998-11-19 | 1 | -0/+34 |
* | Major update/merge of POSIX manual. | Joel Sherrill | 1998-11-19 | 1 | -24/+0 |
* | Updated to include standard number. | Joel Sherrill | 1998-08-13 | 1 | -4/+7 |
* | renamed to user's guide. | Joel Sherrill | 1998-03-26 | 1 | -1/+8 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+12 |
