2017-01-11 | Remove texinfo format documentation. Replaced by Sphinx formatted documentation. | Joel Sherrill | 1 | -745/+0 | |
closes #2812. | |||||
2015-02-25 | posix: fix error return code for pthread_mutex_trylock | Gedare Bloom | 1 | -2/+2 | |
pthread_mutex_trylock() should return EBUSY if the mutex is already locked. The translations of CORE_MUTEX_STATUS_NESTING_NOT_ALLOWED is EDEADLK which is correct for pthread_mutex_lock(). This fixes the translation for trylock. Closes #2170. | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2008-07-18 | 2008-07-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+5 | |
* posix_users/mutex.t: Add ETIMEDOUT. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Fixed spacing. | Joel Sherrill | 1 | -27/+27 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Generated concept and function index entries. | Joel Sherrill | 1 | -98/+194 | |
1999-06-15 | Some stuff added. | Joel Sherrill | 1 | -38/+131 | |
1998-11-19 | Major update/merge of POSIX manual. | Joel Sherrill | 1 | -0/+0 | |
1998-09-29 | Added sentence to indicate sections were deliberately empty. | Joel Sherrill | 1 | -0/+4 | |
1998-08-01 | Removed all node and menu information since this information is now | Joel Sherrill | 1 | -92/+1 | |
automatically generated. Removed any attempts to link across chapter boundaries since the manual is incomplete. | |||||
1998-08-01 | Added automatic generation of files. | Joel Sherrill | 1 | -0/+0 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+2 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+640 | |
