* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Added descriptions for bullet list and routine section headings. | Joel Sherrill | 1999-11-23 | 1 | -8/+8 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 1 | -2/+2 |
* | Generated concept and function index entries. | Joel Sherrill | 1999-10-11 | 1 | -16/+28 |
* | Major update/merge of POSIX manual. | Joel Sherrill | 1998-11-19 | 1 | -0/+140 |
