path: root/doc/posix_users/io.t (follow)
* 2007-09-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-09-241-8/+141
| | | | | | PR 1262/filesystem * posix_users/io.t: Add support for readv() and writev() including documentation and test case.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-0/+37
| | | | | PR 466/doc * io.t: Added sync().
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+1
* Fixed typos.Joel Sherrill2000-01-041-0/+1
* Removed bad descriptions of mount() and umount(). Added shell of anJoel Sherrill1999-11-291-124/+25
| | | | accurate description.
* Fixed spacing.Joel Sherrill1999-11-161-9/+9
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Fixed random cut and paste problem.Joel Sherrill1999-10-111-23/+23
* Generated concept and function index entries.Joel Sherrill1999-10-111-111/+231
* Added descriptions of routines to section headings.Joel Sherrill1999-10-111-18/+18
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-011-4/+4
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Major update/merge of POSIX manual.Joel Sherrill1998-11-191-0/+1085
