path: root/doc/posix_users/clock.t (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-3/+0
* 2004-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-091-3/+59
| | | | | | | PR 464/doc * clock.t, signal.t: Add documentation for usleep() and ualarm(). Also fixed a couple of calls which have the wrong .h files per the OpenGroup site documentation.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+1
* Fixed spacing.Joel Sherrill1999-11-161-5/+5
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Generated concept and function index entries.Joel Sherrill1999-10-111-53/+92
* Added descriptions.Joel Sherrill1999-10-111-8/+8
* Major update/merge of POSIX manual.Joel Sherrill1998-11-191-0/+274
