path: root/doc/posix1003.1 (follow)
* Updated.Joel Sherrill1998-08-131-3/+3
* Changed process group routines to unimplementable.Joel Sherrill1998-05-221-2/+2
* Updated after addition of some routines by Eric Norum.Joel Sherrill1998-05-221-5/+5
* Fixed improperly named sections for infoJoel Sherrill1998-04-033-10/+10
* Completed pass at constants.Joel Sherrill1998-04-034-11/+11
* Added constants through ch13Joel Sherrill1998-04-0211-446/+459
* Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1998-03-301-15/+7
* Corrected distribution levels for htmlJoel Sherrill1998-03-301-2/+1
* Added distribution level to each manualJoel Sherrill1998-03-301-2/+3
* Enhanced.Joel Sherrill1998-03-261-2/+5
* Installed in partners subdirectoryJoel Sherrill1998-03-261-1/+2
* Added Constants, Feature Flags, and Macros (included in Functions).Joel Sherrill1998-03-1817-126/+554
| | | | No status information was included.
* First attempt at adding constants and feature flagsJoel Sherrill1998-03-175-10/+324
* Completed status pass on functions and data types.Joel Sherrill1998-03-1712-33/+48
* Completed first pass at function status.Joel Sherrill1998-03-179-96/+117
| | | | Added most data types without status information.
* Added types, status of functions, cleaned up output of summarize.Joel Sherrill1998-03-169-229/+316
* Added function status and data typesJoel Sherrill1998-03-163-21/+54
* Cleaned up format and added data types.Joel Sherrill1998-03-161-8/+38
* Added Function field.Joel Sherrill1998-03-1615-344/+344
* summarize now generates a nicely formatted function status summary.Joel Sherrill1998-03-162-3/+13
* Function implmentation status information correct.Joel Sherrill1998-03-161-10/+10
* First time summary chapter is included in the document.Joel Sherrill1998-03-163-3/+6
* Added blank lines.Joel Sherrill1998-03-142-0/+12
* Added summary chapter.Joel Sherrill1998-03-141-2/+11
* New file.Joel Sherrill1998-03-141-0/+33
* Added functions from POSIX standard.Joel Sherrill1998-03-147-0/+295
* Added functions from POSIX standard.Joel Sherrill1998-03-143-2/+116
* Added copyright headerJoel Sherrill1998-03-141-0/+8
* Added functions from POSIX standard.Joel Sherrill1998-03-147-7/+686
* Outline complete and apparently correct.Joel Sherrill1998-03-1116-152/+156
* BaselineJoel Sherrill1998-03-1121-0/+754
