* | New files. First attempt. | Joel Sherrill | 2000-04-27 | 1 | -0/+40 |
* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 1 | -62/+28 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | ||||
* | New file. | Joel Sherrill | 2000-02-23 | 1 | -0/+368 |
* | Clarified. | Joel Sherrill | 1999-11-29 | 1 | -0/+2 |
* | Clarified status of mkfifo(). | Joel Sherrill | 1999-11-29 | 1 | -0/+2 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 21 | -81/+91 |
* | Added paragraph describing SUSP. | Joel Sherrill | 1999-11-15 | 1 | -0/+9 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -5/+4 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 8 | -13/+18 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Changed System Database routines to implemented. | Joel Sherrill | 1999-07-03 | 1 | -10/+10 |
* | Added POSIX timers. | Joel Sherrill | 1999-02-10 | 1 | -5/+5 |
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 3 | -7/+7 |
* | making release docs | Joel Sherrill | 1998-10-29 | 2 | -6/+6 |
* | Corrected 2nd invocation of texi2dvi so indices are built. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 |
* | Updated to reflect MG-10 IMFS effort. | Joel Sherrill | 1998-10-12 | 2 | -51/+51 |
* | Updated. | Joel Sherrill | 1998-08-13 | 1 | -3/+3 |
* | Changed process group routines to unimplementable. | Joel Sherrill | 1998-05-22 | 1 | -2/+2 |
* | Updated after addition of some routines by Eric Norum. | Joel Sherrill | 1998-05-22 | 1 | -5/+5 |
* | Fixed improperly named sections for info | Joel Sherrill | 1998-04-03 | 3 | -10/+10 |
* | Completed pass at constants. | Joel Sherrill | 1998-04-03 | 4 | -11/+11 |
* | Added constants through ch13 | Joel Sherrill | 1998-04-02 | 11 | -446/+459 |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 1 | -15/+7 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 1 | -2/+1 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 1 | -2/+3 |
* | Enhanced. | Joel Sherrill | 1998-03-26 | 1 | -2/+5 |
* | Installed in partners subdirectory | Joel Sherrill | 1998-03-26 | 1 | -1/+2 |
* | Added Constants, Feature Flags, and Macros (included in Functions). | Joel Sherrill | 1998-03-18 | 17 | -126/+554 |
| | | | | No status information was included. | ||||
* | First attempt at adding constants and feature flags | Joel Sherrill | 1998-03-17 | 5 | -10/+324 |
* | Completed status pass on functions and data types. | Joel Sherrill | 1998-03-17 | 12 | -33/+48 |
* | Completed first pass at function status. | Joel Sherrill | 1998-03-17 | 9 | -96/+117 |
| | | | | Added most data types without status information. | ||||
* | Added types, status of functions, cleaned up output of summarize. | Joel Sherrill | 1998-03-16 | 9 | -229/+316 |
* | Added function status and data types | Joel Sherrill | 1998-03-16 | 3 | -21/+54 |
* | Cleaned up format and added data types. | Joel Sherrill | 1998-03-16 | 1 | -8/+38 |
* | Added Function field. | Joel Sherrill | 1998-03-16 | 15 | -344/+344 |
* | summarize now generates a nicely formatted function status summary. | Joel Sherrill | 1998-03-16 | 2 | -3/+13 |
* | Function implmentation status information correct. | Joel Sherrill | 1998-03-16 | 1 | -10/+10 |
* | First time summary chapter is included in the document. | Joel Sherrill | 1998-03-16 | 3 | -3/+6 |
* | Added blank lines. | Joel Sherrill | 1998-03-14 | 2 | -0/+12 |
* | Added summary chapter. | Joel Sherrill | 1998-03-14 | 1 | -2/+11 |
* | New file. | Joel Sherrill | 1998-03-14 | 1 | -0/+33 |
* | Added functions from POSIX standard. | Joel Sherrill | 1998-03-14 | 7 | -0/+295 |
* | Added functions from POSIX standard. | Joel Sherrill | 1998-03-14 | 3 | -2/+116 |
* | Added copyright header | Joel Sherrill | 1998-03-14 | 1 | -0/+8 |
* | Added functions from POSIX standard. | Joel Sherrill | 1998-03-14 | 7 | -7/+686 |
* | Outline complete and apparently correct. | Joel Sherrill | 1998-03-11 | 16 | -152/+156 |
* | Baseline | Joel Sherrill | 1998-03-11 | 21 | -0/+754 |
