path: root/doc/posix1003.1/ch07.t (unfollow)
2003-09-192003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-6/+6
* ch07.t, posix1003_1.texi, preface.texi: Merge from branch.
2002-01-172001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation.
1999-11-16Changed copyright date to 1999.Joel Sherrill1-14/+14
1999-10-01Numerous minor changes required to transition to the latest versionJoel Sherrill1-1/+1
of texinfo and TeX. This version of the tools can produce PDF with figures included.
1998-08-13Updated.Joel Sherrill1-3/+3
1998-05-22Changed process group routines to unimplementable.Joel Sherrill1-2/+2
1998-05-22Updated after addition of some routines by Eric Norum.Joel Sherrill1-5/+5
1998-04-03Fixed improperly named sections for infoJoel Sherrill1-5/+5
1998-04-02Added constants through ch13Joel Sherrill1-79/+79
1998-03-18Added Constants, Feature Flags, and Macros (included in Functions).Joel Sherrill1-10/+112
No status information was included.
1998-03-16Added types, status of functions, cleaned up output of summarize.Joel Sherrill1-9/+20
1998-03-16Added Function field.Joel Sherrill1-8/+8
1998-03-14Added functions from POSIX standard.Joel Sherrill1-0/+51
1998-03-11Outline complete and apparently correct.Joel Sherrill1-3/+3
1998-03-11BaselineJoel Sherrill1-0/+43
