2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1998-04-03 | Fixed improperly named sections for info | Joel Sherrill | 1 | -2/+2 | |
1998-04-02 | Added constants through ch13 | Joel Sherrill | 1 | -126/+128 | |
1998-03-18 | Added Constants, Feature Flags, and Macros (included in Functions). | Joel Sherrill | 1 | -107/+117 | |
No status information was included. | |||||
1998-03-17 | First attempt at adding constants and feature flags | Joel Sherrill | 1 | -0/+215 | |
1998-03-17 | Completed status pass on functions and data types. | Joel Sherrill | 1 | -17/+21 | |
1998-03-16 | Added function status and data types | Joel Sherrill | 1 | -0/+20 | |
1998-03-14 | Added blank lines. | Joel Sherrill | 1 | -0/+9 | |
1998-03-11 | Baseline | Joel Sherrill | 1 | -0/+19 | |
