* porting/idlethread.t: Change prototype of IDLE thread to consistently
return void * and take a uintptr_t argument.
* porting/idlethread.t: Correct prototype of Idle threads.
* porting/interrupts.t: Formatting.
* cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t,
cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/sh.t,
cpu_supplement/sparc.t, cpu_supplement/tic4x.t, porting/cpuinit.t,
user/conf.t, user/init.t: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* porting/miscellaneous.t: Remove subsection on "Optional
Endian Conversion Routines", CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore,
develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore,
networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore,
posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* porting/interrupts.t: Fix bogus _CPU_ISR_Get_level.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
* ChangeLog: Merge-in bsp_howto/ChangeLog.
* ChangeLog: Merge-in porting/ChangeLog.
* ChangeLog: Merge-in rgdb_specs/ChangeLog.
* ChangeLog: Merge-in rtems_gdb/ChangeLog.
* bsp_howto/ChangeLog, porting/ChangeLog, rgdb_specs/ChangeLog,
rtems_gdb/ChangeLog: Remove.
* Makefile.am: Cosmetics.
* cpumodels.t: Obsoleting HP PA-RISC port and removing all references.
* porting.texi: Merge from branch.
* cpumodels.t, sourcecode.t: Reconcile differences between CVS trunk
and 4.6 branch.
* cpumodels.t: Removed a29k reference and updated.
* interrupts.t: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
* porting.texi: Set @setfilename porting.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* miscellaneous.t: Added some markups for fonts and clarified
some places.
not that of _ISR_Manager_initialization.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
pdf version of figures.
