Texinfo 5.0 is a complete reimplementation and has stricter
interpretations of the texinfo language.
for details.
PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
* ada_user/version.texi, bsp_howto/version.texi,
cpu_supplement/version.texi, develenv/version.texi,
filesystem/version.texi, networking/version.texi,
porting/version.texi, posix1003.1/version.texi,
posix_users/version.texi, shell/version.texi, started/version.texi,
user/version.texi: Update to match when files in directory where last
touched.
PR 1782/cpukit
* porting/taskcontext.t: Disable deferred FPU context switches when SMP
is enabled. Per code tracking of deferred contexts is not
implemented.
PR 1599/cpukit
* porting/interrupts.t: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
PR 1635/cpukit
* porting/prioritybitmap.t: Refactoring of priority handling, to
isolate the bitmap implementation of priorities in the supercore so
that priority management is a little more modular. This change is in
anticipation of scheduler implementations that can select how they
manage tracking priority levels / finding the highest priority ready
task. Note that most of the changes here are simple renaming, to
clarify the use of the bitmap-based priority management.
PR 1573/cpukit
* porting/interrupts.t: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
* porting/idlethread.t: Change prototype of IDLE thread to consistently
return void * and take a uintptr_t argument.
* porting/idlethread.t: Correct prototype of Idle threads.
* porting/interrupts.t: Formatting.
* cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t,
cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/sh.t,
cpu_supplement/sparc.t, cpu_supplement/tic4x.t, porting/cpuinit.t,
user/conf.t, user/init.t: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* porting/miscellaneous.t: Remove subsection on "Optional
Endian Conversion Routines", CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore,
develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore,
networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore,
posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* porting/interrupts.t: Fix bogus _CPU_ISR_Get_level.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
* ChangeLog: Merge-in bsp_howto/ChangeLog.
* ChangeLog: Merge-in porting/ChangeLog.
* ChangeLog: Merge-in rgdb_specs/ChangeLog.
* ChangeLog: Merge-in rtems_gdb/ChangeLog.
* bsp_howto/ChangeLog, porting/ChangeLog, rgdb_specs/ChangeLog,
rtems_gdb/ChangeLog: Remove.
* Makefile.am: Cosmetics.
* cpumodels.t: Obsoleting HP PA-RISC port and removing all references.
* porting.texi: Merge from branch.
* cpumodels.t, sourcecode.t: Reconcile differences between CVS trunk
and 4.6 branch.
* cpumodels.t: Removed a29k reference and updated.
* interrupts.t: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
* porting.texi: Set @setfilename porting.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* miscellaneous.t: Added some markups for fonts and clarified
some places.
not that of _ISR_Manager_initialization.
