* | 2010-07-29 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-07-29 | 1 | -2/+2 |
| | | | | | | | | | | | PR 1635/cpukit * porting/prioritybitmap.t: Refactoring of priority handling, to isolate the bitmap implementation of priorities in the supercore so that priority management is a little more modular. This change is in anticipation of scheduler implementations that can select how they manage tracking priority levels / finding the highest priority ready task. Note that most of the changes here are simple renaming, to clarify the use of the bitmap-based priority management. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Merged changes from 4.5 branch and removed that branch. | Joel Sherrill | 2000-04-25 | 1 | -5/+38 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added copyrights and CVS Ids. | Joel Sherrill | 1999-10-06 | 1 | -0/+8 |
* | Now builds successfully. | Joel Sherrill | 1999-10-06 | 1 | -1/+1 |
* | New manual. First version to CVS. Just starting to see if it builds. | Joel Sherrill | 1999-10-06 | 1 | -0/+158 |
