closes #2812.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
* cpumodels.t: Obsoleting HP PA-RISC port and removing all references.
* cpumodels.t, sourcecode.t: Reconcile differences between CVS trunk
and 4.6 branch.
* cpumodels.t: Removed a29k reference and updated.
point for portability discussion.
