1998-09-21 | Updated file based upon read_lines received. | Wade A Smith | 1 | -1/+1 | |
1998-09-21 | Updated file based upon red-lines received. | Wade A Smith | 1 | -121/+110 | |
1998-09-21 | Modified sentences in the file to avoid using "shall" statements. | Wade A Smith | 1 | -6/+6 | |
1998-09-21 | Described the constants used by the admin_type in the background section | Wade A Smith | 1 | -10/+14 | |
of this file. | |||||
1998-09-16 | Remove many of the shall verbs and replaced them with present tense verbs | Wade A Smith | 1 | -91/+86 | |
1998-09-13 | Changes the name of readdir, umask, mkdir, chmod, chown to cfg_readdir, | Wade A Smith | 1 | -22/+22 | |
cfg_umask, cfg_mkdir, cfg_chmod, cfg_chown respectively. | |||||
1998-09-12 | Documented the following routines added to the Configuration Space | Wade A Smith | 1 | -1/+488 | |
Management: readdir, open, umask, link, mkdir, unlink, chmod, and chown., | |||||
1998-09-11 | Added documentation for the log_facilityisvalid routine and add thew | Wade A Smith | 1 | -3/+67 | |
status code EINVAL to the log_seek routine. | |||||
1998-09-09 | Added section on format of the configuration space file. | Joel Sherrill | 1 | -0/+2 | |
1998-09-09 | Added gettimeofday(). | Joel Sherrill | 1 | -0/+26 | |
1998-09-02 | Added text to describe System log, Non-system logs,facility, and severity. | Jennifer Averett | 1 | -5/+22 | |
1998-08-31 | Updated the descriptions section for the log_create and log_sys_create | Wade A Smith | 1 | -5/+62 | |
functions.d | |||||
1998-08-28 | Reviewed log_read(). | Joel Sherrill | 1 | -21/+41 | |
1998-08-28 | Reviewed and corrected log_write(), log_write_any(), and log_write_entry(). | Joel Sherrill | 1 | -84/+202 | |
1998-08-28 | Added log_write_any and part of log_copy. | Joel Sherrill | 1 | -3/+92 | |
Reviewed log_close. | |||||
1998-08-27 | Updated log_seek() per review. | Joel Sherrill | 1 | -14/+10 | |
1998-08-27 | Modified log_open() to reflect review. | Joel Sherrill | 1 | -26/+29 | |
1998-08-27 | Corrected descriptions of log facility set manipulation routines as | Joel Sherrill | 1 | -130/+59 | |
part of the review. | |||||
1998-08-27 | Corrected log_severity_before as part of reviewing the code. | Joel Sherrill | 1 | -7/+16 | |
1998-08-26 | Incorporated the "#include <dump.h>" statement in file. | Wade A Smith | 1 | -0/+2 | |
1998-08-26 | Incorporated the "#include cfg.h" statement in document | Wade A Smith | 1 | -0/+24 | |
1998-08-26 | Incorporated the "#include <admin.h>" statement in file | Wade A Smith | 1 | -0/+2 | |
1998-08-26 | Corrected mispelled words. | Wade A Smith | 1 | -2/+30 | |
1998-08-25 | Added some background and operations subsections. | Joel Sherrill | 3 | -0/+20 | |
1998-08-25 | Fixed spelling mistakes. | Joel Sherrill | 2 | -41/+41 | |
1998-08-25 | Fixed spelling mistake. | Joel Sherrill | 1 | -1/+1 | |
1998-08-25 | Cleaned up formatting. | Joel Sherrill | 4 | -789/+906 | |
Added notes on background and operations sections. Added NOTE to indicate the feature flag defined. | |||||
1998-08-25 | Commit for review | Joel Sherrill | 4 | -77/+77 | |
1998-08-25 | Documented the log_create and log_sys_create routines | Wade A Smith | 1 | -0/+76 | |
1998-08-12 | Updated the description section of the cfg_open and cfg_read routines | Wade A Smith | 1 | -20/+155 | |
1998-08-11 | Updated the description section of the admin_shutdown routine. | Wade A Smith | 1 | -1/+14 | |
1998-08-11 | Updated the description section for the dump_setpath routine. | Wade A Smith | 1 | -2/+16 | |
1998-08-11 | Updated the description section for the following routines: | Wade A Smith | 1 | -7/+228 | |
log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember | |||||
1998-08-11 | Updated the Description section for the following routines: | Wade A Smith | 1 | -2/+75 | |
log_notify, log_read, log_open, and log_write. | |||||
1998-08-10 | Update the description section for the log_write function. | Wade A Smith | 1 | -3/+38 | |
1998-08-10 | Updated the Description section for the Configuration Space Management | Wade A Smith | 1 | -93/+224 | |
routines. | |||||
1998-08-10 | Added to the description section of the Configuration Space Operations. | Wade A Smith | 1 | -9/+77 | |
1998-08-10 | Documented the admin_shutdown function | Wade A Smith | 1 | -4/+13 | |
1998-08-10 | Documented the following Event Logging routines: | Wade A Smith | 1 | -48/+172 | |
log_write, log_open, log_read, log_notify, log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember | |||||
1998-08-10 | Documented the dump_setpath function. | Wade A Smith | 1 | -4/+22 | |
1998-08-10 | Added documentation for the following Configuration Space Operations: | Wade A Smith | 1 | -46/+342 | |
cfg_mount, cfg_unmount, cfg_mknod, cfg_set, cfg_get, cfg_link, cfg_unlink, cfg_open, cfg_read, cfg_children, cfg_mark, and cfg_close | |||||
1998-08-04 | More complete shells generated. | Joel Sherrill | 18 | -277/+1245 | |
1998-08-03 | Added many new chapters | Joel Sherrill | 18 | -15/+3791 | |
1998-08-01 | Changed to be posix users "new" | Joel Sherrill | 1 | -2/+4 | |
1998-08-01 | Added files and directories. | Joel Sherrill | 1 | -1/+9 | |
1998-08-01 | Fixed to add files and directories. | Joel Sherrill | 1 | -7/+13 | |
Fixed so this is installed as "POSIX Users New" | |||||
1998-08-01 | Added process and procenv. | Joel Sherrill | 1 | -3/+15 | |
1998-08-01 | Added language variables. | Joel Sherrill | 1 | -1/+14 | |
1998-08-01 | Now generates complete template for chapters. | Joel Sherrill | 1 | -53/+85 | |
1998-08-01 | New files -- automatically gnerated templates. | Joel Sherrill | 2 | -0/+722 | |
