path: root/doc/new_chapters (follow)
* Remove many of the shall verbs and replaced them with present tense verbsWade A Smith1998-09-161-91/+86
* Changes the name of readdir, umask, mkdir, chmod, chown to cfg_readdir,Wade A Smith1998-09-131-22/+22
| | | | cfg_umask, cfg_mkdir, cfg_chmod, cfg_chown respectively.
* Documented the following routines added to the Configuration SpaceWade A Smith1998-09-121-1/+488
| | | | Management: readdir, open, umask, link, mkdir, unlink, chmod, and chown.,
* Added documentation for the log_facilityisvalid routine and add thewWade A Smith1998-09-111-3/+67
| | | | status code EINVAL to the log_seek routine.
* Added section on format of the configuration space file.Joel Sherrill1998-09-091-0/+2
* Added gettimeofday().Joel Sherrill1998-09-091-0/+26
* Added text to describe System log, Non-system logs,facility, and severity.Jennifer Averett1998-09-021-5/+22
* Updated the descriptions section for the log_create and log_sys_createWade A Smith1998-08-311-5/+62
| | | | functions.d
* Reviewed log_read().Joel Sherrill1998-08-281-21/+41
* Reviewed and corrected log_write(), log_write_any(), and log_write_entry().Joel Sherrill1998-08-281-84/+202
* Added log_write_any and part of log_copy.Joel Sherrill1998-08-281-3/+92
| | | | Reviewed log_close.
* Updated log_seek() per review.Joel Sherrill1998-08-271-14/+10
* Modified log_open() to reflect review.Joel Sherrill1998-08-271-26/+29
* Corrected descriptions of log facility set manipulation routines asJoel Sherrill1998-08-271-130/+59
| | | | part of the review.
* Corrected log_severity_before as part of reviewing the code.Joel Sherrill1998-08-271-7/+16
* Incorporated the "#include <dump.h>" statement in file.Wade A Smith1998-08-261-0/+2
* Incorporated the "#include cfg.h" statement in documentWade A Smith1998-08-261-0/+24
* Incorporated the "#include <admin.h>" statement in fileWade A Smith1998-08-261-0/+2
* Corrected mispelled words.Wade A Smith1998-08-261-2/+30
* Added some background and operations subsections.Joel Sherrill1998-08-253-0/+20
* Fixed spelling mistakes.Joel Sherrill1998-08-252-41/+41
* Fixed spelling mistake.Joel Sherrill1998-08-251-1/+1
* Cleaned up formatting.Joel Sherrill1998-08-254-789/+906
| | | | | | Added notes on background and operations sections. Added NOTE to indicate the feature flag defined.
* Commit for reviewJoel Sherrill1998-08-254-77/+77
* Documented the log_create and log_sys_create routinesWade A Smith1998-08-251-0/+76
* Updated the description section of the cfg_open and cfg_read routinesWade A Smith1998-08-121-20/+155
* Updated the description section of the admin_shutdown routine.Wade A Smith1998-08-111-1/+14
* Updated the description section for the dump_setpath routine.Wade A Smith1998-08-111-2/+16
* Updated the description section for the following routines:Wade A Smith1998-08-111-7/+228
| | | | | | log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember
* Updated the Description section for the following routines:Wade A Smith1998-08-111-2/+75
| | | | log_notify, log_read, log_open, and log_write.
* Update the description section for the log_write function.Wade A Smith1998-08-101-3/+38
* Updated the Description section for the Configuration Space ManagementWade A Smith1998-08-101-93/+224
| | | | routines.
* Added to the description section of the Configuration Space Operations.Wade A Smith1998-08-101-9/+77
* Documented the admin_shutdown functionWade A Smith1998-08-101-4/+13
* Documented the following Event Logging routines:Wade A Smith1998-08-101-48/+172
| | | | | | log_write, log_open, log_read, log_notify, log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember
* Documented the dump_setpath function.Wade A Smith1998-08-101-4/+22
* Added documentation for the following Configuration Space Operations:Wade A Smith1998-08-101-46/+342
| | | | | cfg_mount, cfg_unmount, cfg_mknod, cfg_set, cfg_get, cfg_link, cfg_unlink, cfg_open, cfg_read, cfg_children, cfg_mark, and cfg_close
* More complete shells generated.Joel Sherrill1998-08-0418-277/+1245
* Added many new chaptersJoel Sherrill1998-08-0318-15/+3791
* Changed to be posix users "new"Joel Sherrill1998-08-011-2/+4
* Added files and directories.Joel Sherrill1998-08-011-1/+9
* Fixed to add files and directories.Joel Sherrill1998-08-011-7/+13
| | | | Fixed so this is installed as "POSIX Users New"
* Added process and procenv.Joel Sherrill1998-08-011-3/+15
* Added language variables.Joel Sherrill1998-08-011-1/+14
* Now generates complete template for chapters.Joel Sherrill1998-08-011-53/+85
* New files -- automatically gnerated templates.Joel Sherrill1998-08-012-0/+722
* New fileJoel Sherrill1998-08-011-0/+65
* Removed items which are now automatically generated.Joel Sherrill1998-08-011-41/+1
* New file.Joel Sherrill1998-08-011-0/+98
* Removed all node and menu information since this information is nowJoel Sherrill1998-08-019-563/+12
| | | | | | | automatically generated. Removed any attempts to link across chapter boundaries since the manual is incomplete.
