* new_chapters/Makefile.am, new_chapters/gen_section,
new_chapters/new_chapters.texi, user/Makefile.am, user/c_user.texi,
user/dirstat.texi: Promote CPU Usage to first class citizen. Rename
to start with rtems_ and include documentation in user guide.
* user/cpuuse.t: New file.
* new_chapters/cpuuse.t: Removed.
* eventlog.t: Remove.
* new_chapters.texi: Remove eventlog.
* Makefile.am: Remove eventlog.
* dumpcontrol.t: Remove.
* new_chapters.texi: Remove dumpcontrol.
* Makefile.am: Remove dumpcontrol.
* confspace.t: Remove.
* new_chapters.texi: Remove confspace.
* Makefile.am: Remove confspace.
* adminiface.t: Remove.
* new_chapters.texi: Remove adminiface.
* Makefile.am: Remove adminiface.
* new_chapters.texi: Merge from branch.
* new_chapters.texi: Set @setfilename new_chapters.info.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
figures included.
