path: root/doc/new_chapters/eventlog.t (follow)
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Fixed typo.Joel Sherrill1998-10-121-1/+1
* Updated the STATUS CODE section of the routines in this file.Wade A Smith1998-09-301-0/+48
* Made formatting changes to the fileWade A Smith1998-09-301-8/+18
* Updated file based upon red-lines received.Wade A Smith1998-09-211-121/+110
* Added documentation for the log_facilityisvalid routine and add thewWade A Smith1998-09-111-3/+67
| | | | status code EINVAL to the log_seek routine.
* Added text to describe System log, Non-system logs,facility, and severity.Jennifer Averett1998-09-021-5/+22
* Updated the descriptions section for the log_create and log_sys_createWade A Smith1998-08-311-5/+62
| | | | functions.d
* Reviewed log_read().Joel Sherrill1998-08-281-21/+41
* Reviewed and corrected log_write(), log_write_any(), and log_write_entry().Joel Sherrill1998-08-281-84/+202
* Added log_write_any and part of log_copy.Joel Sherrill1998-08-281-3/+92
| | | | Reviewed log_close.
* Updated log_seek() per review.Joel Sherrill1998-08-271-14/+10
* Modified log_open() to reflect review.Joel Sherrill1998-08-271-26/+29
* Corrected descriptions of log facility set manipulation routines asJoel Sherrill1998-08-271-130/+59
| | | | part of the review.
* Corrected log_severity_before as part of reviewing the code.Joel Sherrill1998-08-271-7/+16
* Corrected mispelled words.Wade A Smith1998-08-261-2/+30
* Fixed spelling mistakes.Joel Sherrill1998-08-251-14/+14
* Cleaned up formatting.Joel Sherrill1998-08-251-372/+364
| | | | | | Added notes on background and operations sections. Added NOTE to indicate the feature flag defined.
* Commit for reviewJoel Sherrill1998-08-251-22/+22
* Documented the log_create and log_sys_create routinesWade A Smith1998-08-251-0/+76
* Updated the description section for the following routines:Wade A Smith1998-08-111-7/+228
| | | | | | log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember
* Updated the Description section for the following routines:Wade A Smith1998-08-111-2/+75
| | | | log_notify, log_read, log_open, and log_write.
* Update the description section for the log_write function.Wade A Smith1998-08-101-3/+38
* Documented the following Event Logging routines:Wade A Smith1998-08-101-48/+172
| | | | | | log_write, log_open, log_read, log_notify, log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember
* More complete shells generated.Joel Sherrill1998-08-041-12/+84
* Added many new chaptersJoel Sherrill1998-08-031-0/+295
