* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Updated the STATUS CODE section for the routines in this file. | Wade A Smith | 1998-09-30 | 1 | -394/+142 |
* | Updated file based upon red-lines received. | Wade A Smith | 1998-09-21 | 1 | -15/+11 |
* | Remove many of the shall verbs and replaced them with present tense verbs | Wade A Smith | 1998-09-16 | 1 | -91/+86 |
* | Changes the name of readdir, umask, mkdir, chmod, chown to cfg_readdir, | Wade A Smith | 1998-09-13 | 1 | -22/+22 |
| | | | | cfg_umask, cfg_mkdir, cfg_chmod, cfg_chown respectively. | ||||
* | Documented the following routines added to the Configuration Space | Wade A Smith | 1998-09-12 | 1 | -1/+488 |
| | | | | Management: readdir, open, umask, link, mkdir, unlink, chmod, and chown., | ||||
* | Added section on format of the configuration space file. | Joel Sherrill | 1998-09-09 | 1 | -0/+2 |
* | Incorporated the "#include cfg.h" statement in document | Wade A Smith | 1998-08-26 | 1 | -0/+24 |
* | Added some background and operations subsections. | Joel Sherrill | 1998-08-25 | 1 | -0/+14 |
* | Fixed spelling mistakes. | Joel Sherrill | 1998-08-25 | 1 | -27/+27 |
* | Cleaned up formatting. | Joel Sherrill | 1998-08-25 | 1 | -378/+462 |
| | | | | | | Added notes on background and operations sections. Added NOTE to indicate the feature flag defined. | ||||
* | Commit for review | Joel Sherrill | 1998-08-25 | 1 | -50/+50 |
* | Updated the description section of the cfg_open and cfg_read routines | Wade A Smith | 1998-08-12 | 1 | -20/+155 |
* | Updated the Description section for the Configuration Space Management | Wade A Smith | 1998-08-10 | 1 | -93/+224 |
| | | | | routines. | ||||
* | Added to the description section of the Configuration Space Operations. | Wade A Smith | 1998-08-10 | 1 | -9/+77 |
* | Added documentation for the following Configuration Space Operations: | Wade A Smith | 1998-08-10 | 1 | -46/+342 |
| | | | | | cfg_mount, cfg_unmount, cfg_mknod, cfg_set, cfg_get, cfg_link, cfg_unlink, cfg_open, cfg_read, cfg_children, cfg_mark, and cfg_close | ||||
* | More complete shells generated. | Joel Sherrill | 1998-08-04 | 1 | -13/+89 |
* | Added many new chapters | Joel Sherrill | 1998-08-03 | 1 | -0/+295 |
