* Makefile.am, gen_section: Integrate Rate Monotonic Statistics and
Period Usage into Rate Monotonic Manager. Added the following
directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtmonuse.t: Removed.
* new_chapters/Makefile.am, new_chapters/gen_section,
new_chapters/new_chapters.texi, user/Makefile.am, user/c_user.texi,
user/dirstat.texi: Promote CPU Usage to first class citizen. Rename
to start with rtems_ and include documentation in user guide.
* user/cpuuse.t: New file.
* new_chapters/cpuuse.t: Removed.
* new_chapters/Makefile.am, user/Makefile.am, user/c_user.texi,
user/dirstat.texi, user/task.t: Move stack to first class citizen
status. Include it in User Manual and rename to start with rtems_.
* user/stackchk.t: New file.
* new_chapters/stackchk.t: Removed.
* base.t: Remove.
* Makefile.am: Remove base.t.
* eventlog.t: Remove.
* new_chapters.texi: Remove eventlog.
* Makefile.am: Remove eventlog.
* dumpcontrol.t: Remove.
* new_chapters.texi: Remove dumpcontrol.
* Makefile.am: Remove dumpcontrol.
* confspace.t: Remove.
* new_chapters.texi: Remove confspace.
* Makefile.am: Remove confspace.
* adminiface.t: Remove.
* new_chapters.texi: Remove adminiface.
* Makefile.am: Remove adminiface.
* Makefile.am: Cosmetics.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
