* new_chapters.texi: Print table of contents in front of manual where
it should be when you print.
* Makefile.am, gen_section: Integrate Rate Monotonic Statistics and
Period Usage into Rate Monotonic Manager. Added the following
directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtmonuse.t: Removed.
* base.t: Remove.
* Makefile.am: Remove base.t.
* eventlog.t: Remove.
* new_chapters.texi: Remove eventlog.
* Makefile.am: Remove eventlog.
* dumpcontrol.t: Remove.
* new_chapters.texi: Remove dumpcontrol.
* Makefile.am: Remove dumpcontrol.
* confspace.t: Remove.
* new_chapters.texi: Remove confspace.
* Makefile.am: Remove confspace.
* adminiface.t: Remove.
* new_chapters.texi: Remove adminiface.
* Makefile.am: Remove adminiface.
* Makefile.am: Cosmetics.
* new_chapters.texi: Merge from branch.
* new_chapters.texi: Set @setfilename new_chapters.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
