See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html
for instructions on how to do this.
Texinfo 5.0 is a complete reimplementation and has stricter
interpretations of the texinfo language.
for details.
PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
* ada_user/version.texi, bsp_howto/version.texi,
cpu_supplement/version.texi, develenv/version.texi,
filesystem/version.texi, networking/version.texi,
porting/version.texi, posix1003.1/version.texi,
posix_users/version.texi, shell/version.texi, started/version.texi,
user/version.texi: Update to match when files in directory where last
touched.
* networking/networkapp.t: Updated the BOOTP/DHCP to document the
default behaviour of looping forever.
* networking/testing.t: Cleaned up the patch from Ian.
* networking/testing.t: Patch from Ian Caddy to document the
routes debug information.
* networking/networkapp.t: Add configuration parameters for network
stack efficiency multiplier and default socket buffer sizes.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore,
develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore,
networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore,
posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* networking/decdriver.t: Make PCI initialize function part of the
unified PCI API as pci_initialize().
* networking/networkflow.txt, networking/PCIreg.txt,
networking/recvbd.txt: New.
* networking/decdriver.t, networking/networktasks.t: Use @image for
ASCII figures (Reflect changes above).
* ChangeLog: Merge-in filesystem/ChangeLog.
* ChangeLog: Merge-in networking/ChangeLog.
* filesystem/ChangeLog, networking/ChangeLog: Remove.
* Makefile.am: Cosmetics.
* networkapp.t, preface.texi: Improve documentation for SO_RCVWAKEUP
and SO_SNDWAKEUP and update the references in the preface.
* networking.texi: Merge from branch.
* networkapp.t: Add an example code snippet for adding a default route.
* networkapp.t: Add an example code snippet for adding an IP alias.
* networking.texi: Set @setfilename networking.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2001-01-17 Joel Sherrill <joel@OARcorp.com>
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
- char * nameserver[3] appears twice, second occurrence should be ntpserver
- in sect 3.3.3 ...ifcontig should be ifconfig
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
