* | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1998-11-19 | 2 | -11/+12 |
* | Changed version string. | Joel Sherrill | 1998-11-19 | 2 | -2/+2 |
| | | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | ||||
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 1 | -1/+1 |
* | Clarifed description of driver name. | Joel Sherrill | 1998-10-27 | 1 | -1/+4 |
* | Added some fields and changed last KA9Q reference to FreeBSD. | Joel Sherrill | 1998-10-12 | 1 | -1/+12 |
* | Fixed back so it would build. | Joel Sherrill | 1998-09-10 | 1 | -0/+2 |
* | Added references. | Joel Sherrill | 1998-09-10 | 1 | -0/+33 |
* | Removed chapter names from automatically generated node names. | Joel Sherrill | 1998-09-08 | 2 | -3/+5 |
* | Fixed include file path. | Joel Sherrill | 1998-09-08 | 1 | -1/+1 |
* | Patch from Eric Norum | Joel Sherrill | 1998-08-21 | 1 | -10/+9 |
* | Update from Eric Norum. | Joel Sherrill | 1998-08-21 | 1 | -4/+23 |
* | First version produced. | Joel Sherrill | 1998-08-19 | 3 | -2/+3 |
* | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 1998-08-19 | 5 | -21/+21 |
* | Baseline | Joel Sherrill | 1998-08-19 | 9 | -0/+2321 |
