relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
- char * nameserver[3] appears twice, second occurrence should be ntpserver
- in sect 3.3.3 ...ifcontig should be ifconfig
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
the network initialization enhancement request by Jake Janovetz
<janovetz@tempest.ece.uiuc.edu>.
of the C definition of the configuration structure.
backwards.
did not display the png properly.
viewer can have section headings.
Added stanza to generate pdf files from eps ones.
tool problems.
figures included.
getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor
<ian@airs.com>.
parsing of interface names.
