path: root/doc/networking (follow)
* Update dateJoel Sherrill2015-07-171-2/+2
* doc: Document network task affinity optionDaniel Cederman2015-02-111-0/+14
* doc master include files: Do not include top node on printed outputJoel Sherrill2013-02-261-0/+2
| | | | | | In PDF, DVI, and PostScript files, the contents of the @top node were being printed. These are intended only for info and html output formats.
* doc: Update version.texi and stamp-vti filesJoel Sherrill2013-02-262-4/+4
| | | | | See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html for instructions on how to do this.
* doc: Update to build info format with texinfo 4.13 and 5.0Joel Sherrill2013-02-261-8/+9
| | | | | Texinfo 5.0 is a complete reimplementation and has stricter interpretations of the texinfo language.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-119-27/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+3
* Remove CVS-Ids.Ralf Corsépius2012-05-041-3/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-28/+0
* 2011-12-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-063-16/+3
| | | | | | | | | | | | | | | | | | | | | | | PR 1793/doc * .cvsignore, Makefile.am, README, configure.ac, index.html.in, main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi, ada_user/example.texi, bsp_howto/.cvsignore, bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore, cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi, develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi, filesystem/.cvsignore, filesystem/filesystem.texi, filesystem/preface.texi, networking/.cvsignore, networking/networking.texi, networking/preface.texi, porting/.cvsignore, porting/porting.texi, porting/preface.texi, posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi, posix_users/.cvsignore, posix_users/posix_users.texi, posix_users/preface.texi, shell/.cvsignore, shell/preface.texi, shell/shell.texi, started/.cvsignore, started/started.texi, user/.cvsignore, user/c_user.texi, user/dirstat.texi, user/example.texi, user/glossary.texi, user/preface.texi: Convert from texi2www to texi2html. * texi2html_init.in: New file. * rtems_footer.html.in, rtems_header.html.in: Removed.
* 2011-12-05 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-12-051-2/+2
| | | | | | | | | | * ada_user/version.texi, bsp_howto/version.texi, cpu_supplement/version.texi, develenv/version.texi, filesystem/version.texi, networking/version.texi, porting/version.texi, posix1003.1/version.texi, posix_users/version.texi, shell/version.texi, started/version.texi, user/version.texi: Update to match when files in directory where last touched.
* New.Ralf Corsepius2010-06-112-0/+8
* Remove EDITION (Unused)Ralf Corsepius2010-06-112-3/+0
* 2010-02-18 Chris Johns <chrisj@rtems.org>Chris Johns2010-02-181-7/+25
| | | | | * networking/networkapp.t: Updated the BOOTP/DHCP to document the default behaviour of looping forever.
* Convert to "bool".Ralf Corsepius2008-09-091-2/+2
* 2008-03-29 Chris Johns <chrisj@rtems.org>Chris Johns2008-03-291-20/+32
| | | | * networking/testing.t: Cleaned up the patch from Ian.
* 2008-03-29 Chris Johns <chrisj@rtems.org>Chris Johns2008-03-291-0/+99
| | | | | * networking/testing.t: Patch from Ian Caddy to document the routes debug information.
* 2008-02-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-02-051-5/+62
| | | | | * networking/networkapp.t: Add configuration parameters for network stack efficiency multiplier and default socket buffer sizes.
* 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-06-211-1/+2
| | | | | | | | | | | | * ada_user/ada_user.texi, bsp_howto/bsp_howto.texi, cpu_supplement/cpu_supplement.texi, develenv/develenv.texi, filesystem/filesystem.texi, itron3.0/itron.texi, networking/networking.texi, porting/porting.texi, posix1003.1/posix1003_1.texi, posix_users/posix_users.texi, rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi, started/started.texi, started_ada/started_ada.texi, user/c_user.texi: Print table of contents in front of manual where it should be when you print.
* 2006-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-10-261-0/+12
| | | | | | | * ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore, develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore, networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore, posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* Provoke cvs complaints on generated docs.Ralf Corsepius2006-01-191-11/+0
* 2005-03-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-03-041-1/+1
| | | | | * networking/decdriver.t: Make PCI initialize function part of the unified PCI API as pci_initialize().
* 2004-07-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-07-315-39/+16
| | | | | | | * networking/networkflow.txt, networking/PCIreg.txt, networking/recvbd.txt: New. * networking/decdriver.t, networking/networktasks.t: Use @image for ASCII figures (Reflect changes above).
* 2004-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-051-77/+0
| | | | | | * ChangeLog: Merge-in filesystem/ChangeLog. * ChangeLog: Merge-in networking/ChangeLog. * filesystem/ChangeLog, networking/ChangeLog: Remove.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-1/+4
| | | | * Makefile.am: Cosmetics.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-112-1/+5
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-262-0/+7
| | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos.
* 2003-10-02 Gene Smith <gene.smith@siemens.com>Joel Sherrill2003-10-023-7/+56
| | | | | * networkapp.t, preface.texi: Improve documentation for SO_RCVWAKEUP and SO_SNDWAKEUP and update the references in the preface.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-222-2/+5
| | | | * Makefile.am: Merger from rtems-4-6-branch.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-192-0/+5
| | | | * networking.texi: Merge from branch.
* 2003-02-11 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2003-02-112-1/+324
| | | | * networkapp.t: Add an example code snippet for adding a default route.
* 2003-02-11 Mike Siers <mikes@poliac.com>Joel Sherrill2003-02-112-0/+38
| | | | * networkapp.t: Add an example code snippet for adding an IP alias.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-252-1/+5
| | | | * networking.texi: Set @setfilename networking.info.
* 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-242-7/+11
| | | | * Makefile.am: Put GENERATED_FILES into $builddir.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-224-14/+16
| | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort.
* 2003-01-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-213-4/+8
| | | | * stamp-vti, version.texi: Regenerated.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-133-4/+8
* 2002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-243-4/+8
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-301-2/+2
| | | | | * stamp-vti, verstion.texi: Regenerated.
| | | | | | | | | | | | | | | | | | | | * stamp-vti, verstion.texi: Regenerated. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Remove AUTOMAKE_OPTIONS. 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: include main.am, require automake-1.5. 2001-01-17 Joel Sherrill <joel@OARcorp.com> * .cvsignore: Added rtems_header.html and rtems_footer.html. 2000-08-10 Joel Sherrill <joel@OARcorp.com> * ChangeLog: New file.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-282-1/+4
* regeneratedJoel Sherrill2002-01-202-4/+6
* regeneratedJoel Sherrill2002-01-202-4/+4
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-182-1/+7
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-172-0/+6
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-1710-12/+13
* Adding ChangeLogs.Joel Sherrill2000-08-251-0/+3
* Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill2000-06-141-1/+0
| | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
* Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-102-5/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
* Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-06-015-47/+44
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
